Date/Time: Tue, 25 Feb 2025 09:56:58 +0000
Can't find [CBOTM] Mini Corn/Wheat/Soybean with Delayed data
View Count: 607
[2021-04-08 11:19:51] |
User893204 - Posts: 6 |
Hello, I am trying to open intraday charts for [CBOTM] Corn Mini (XN), Wheat mini (XW) and Soybean mini (XK), with the Delayed data service. but they don't appear on the list, I have tried searching for them with no results, albeit [CBOTM] Mini Dow (YM) and Micro dow (MYM) do appear? Can I access those contracts with the delayed service in any way? Thanks |
[2021-04-08 22:09:40] |
We will set these up.
[2021-04-09 11:12:01] |
Thank you, do you have an estimated time for when those contracts will be available for the delayed service? Thanks |
[2021-04-09 19:31:05] |
It will be done today or over the weekend.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-09 19:31:12
[2021-04-10 01:52:58] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
