Date/Time: Tue, 25 Feb 2025 07:53:23 +0000
Market Depth
View Count: 512
[2021-04-08 01:44:45] |
Ricardo Zurek - Posts: 18 |
Hi, how can I activate the full market depth. I just subscribed to Denali and the sierra chart exchange fee. I have all settings at 0 to see the full market depth but I can not see the 1400 levels. Which settings should I change? Thank you |
[2021-04-08 04:28:00] |
You do have the market depth data, but you are not necessarily going to see 1400 levels. It depends on how many levels there are for the symbol at any given moment.
