Date/Time: Tue, 25 Feb 2025 13:43:01 +0000
RTY Chart not working
View Count: 514
[2021-04-07 22:18:12] |
User122513 - Posts: 28 |
My RTY chart is not working since March 26th and I do have live data for ES, NQ and RTY, but RTY is the only one not working.
[2021-04-08 09:29:57] |
User907968 - Posts: 833 |
You've posted this on the User Discussion board. SC engineers do not look at this board. You need to post this on the Main support board. |
[2021-04-16 14:15:36] |
First thing we want you to do is to update Sierra Chart to the current version. You should be receiving delayed data. Refer to: Software Download: Fast Update Make sure you are using the current symbols also by using this Edit menu command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
