Date/Time: Tue, 25 Feb 2025 07:51:20 +0000
I just dont get it.
View Count: 525
[2021-04-07 22:10:53] |
M2m48 - Posts: 10 |
Presently I have package 5 till September. I was indicated that if I want real time data (previously IB) than I need to upgrade and add a another Service Package. Now all I want is Sierra Chart Exchange Data Feed , I don't trade usually trard COMEX, NYMEX, etc. All I trade is Nasdaq, American, NY Stock Exchange, if emini (CME) is available that would be great . What do I order I need to get back to speed. Do I get Delali also ?? Thank You Mark2m |
[2021-04-08 15:06:50] |
John - SC Support - Posts: 38150 |
If you are just looking for the data for the U.S. Stocks, then you would use the Sierra Chart Exchange Data Feed and activate the U.S. Equities exchange within it. Refer to the information on the following page, including Setup Instructions: Sierra Chart Exchange Data Feed You have access to the Delayed Streaming data for the E-Mini S&P 500 and the rest of the data from the CME Group. It is delayed by 10 minutes and 10 seconds. If this is adequate, then you do not need to do anything further. If you do want to get Real-Time data for any of the CME Group, then you would need to use the Denali Exchange Data Feed and activate the appropriate exchanges within it. Refer to the information at the following page, including Setup Instructions: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
