Date/Time: Tue, 25 Feb 2025 08:31:25 +0000
How to use DRAWSTYLE_POINT_VARIABLE_SIZE?
View Count: 617
[2021-04-07 21:56:40]
User719512 - Posts: 299
Do you have an example or can you add clarification to the Docs for how to use DRAWSTYLE_POINT_VARIABLE_SIZE?
See my related thread at How to use DRAWSTYLE_POINT_VARIABLE_SIZE? Getting strange painting and chart scale.
I am sure I am missing something basic, and I don't see any threads here, nor examples on the internet either for how to use DRAWSTYLE_POINT_VARIABLE_SIZE.
Thank you,
Kory
[2021-04-08 18:22:15]
Hi, Just discovered this does not work if the Graph Draw Type is Blank. My study started working as expected once I set the Graph Draw Type to non-Blank (Line, Stair Step on Close, etc). We can close this request, but perhaps for others sample code would be a nice addition sometime. The sample code you provide is really helpful and much appreciated! Thanks, Kory
