Date/Time: Tue, 25 Feb 2025 08:04:48 +0000
Live Trading
View Count: 607
[2021-04-07 20:20:08]
User344478 - Posts: 157
What you can recommend me for Live trading in my case-PACKAGE 10 ?
[2021-04-07 20:40:41]
John - SC Support - Posts: 38150
We do not understand your question.
It appears that you are setup with CQG for your order routing and you are getting data through the Denali Exchange Data Feed.
[2021-04-08 13:38:36]
Hi John,
I am learning setup with CQG for my order routing and getting data through the Denali Exchange Data Feed.
I will text you result of my experience in a couple hours.
Gennady
[2021-04-08 18:10:24]
Hi John,
1. In Technical Notice : Custom Study Improperly Altering Time Scale of Chart.
2. In Message Log:
-No download requests in the queue to start downloads for.
-Round trip delay : 00:00:00.277.
-Computer time to server time difference:- 00:00:04.580.
-Error setting system Date_ Time windows error code 1314 : A required privelege is not held by the client.
3. I do not have "STOP LINE" on some charts.
Gennady
[2021-04-08 19:27:24]
1. Do not worry about this. It is just a notice. If you do have issues with the time at the bottom of your charts all showing zeros, then it is a problem with a custom study you have.
2.These are nothing to be concerned with. Regarding the time setting, refer to the following:
Global Settings Menu: Set System Date-Time from Server (Global Settings menu)
3. We do not know what you mean by "STOP LINE". Are you referring to a stop attached order line, or something else?
[2021-04-08 20:23:43]
YES THAT IS a stop attached order line.
[2021-04-08 21:26:44]
Are you placing both a Stop and a Target? Are you able to see the information for the Target?
In general, refer to the following setting and the 3 settings that are below it related to Trade Drawings:
Chart Settings: Align Order Cancel (X) Button to Right (Chart >> Chart Settings >> Trading menu)
Also, it's possible that your Stop is simply far enough away that it is outside the current viewing area of the chart. You would need to adjust your scales to be able to see it. Refer to the following:
Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale
