Date/Time: Tue, 25 Feb 2025 08:36:08 +0000
Cannot Open Sierra
View Count: 392
[2021-04-07 19:07:47]
User176071 - Posts: 7
Staring today, I cannot open Sierra. If I restart Windows 10, I can click the icon and Open. But when I close the application, I cannot re-open at all.
[2021-04-07 19:14:15]
John - SC Support - Posts: 38150
We have been noticing a recent issue with Trend Micro mistakenly thinking that the Sierra Chart executable has/is a virus and then stopping it from starting.
If you are using Trend Micro, then you need to add an exception to allow sierrachart_64.exe to run.
If you are not using Trend Micro, or if you need some help with this, let us know.
