Date/Time: Tue, 25 Feb 2025 08:17:57 +0000
Rithmic Connection issue - through RTraderPro(Bridge Mode)
View Count: 598
[2021-04-07 18:57:04]
ejtrader - Posts: 688
SC Team - Do you currently support rithmic connection or you don't?
My prior question was marked as User discussion - Rithmic bridge connection issue. Please help. Thanks in advance
- SC/Rithmic - Direct mode works fine
- SC to Rithmic using RTrader Pro (Bridge mode) doesn't work (it would disconnect Rtrader Pro due to connection limit). This is not an issue with some other programs (including Ninja/MC).
Would you please answer rather than marking it as user discussion?
For any other users - wondering if any of you use rithmic using bridge mode.
[2021-04-07 20:20:26]
ertrader - Posts: 681
My understanding is that bridge mode thru Rtrader pro is not supported. Only the interim DTC Bridge server solution until the new Rithmic interface is implemented. The DTC Bridge server is what I currently use. When I log into Rtrader, SC must be disconnected.
Date Time Of Last Edit: 2021-04-07 20:22:17
