Date/Time: Tue, 25 Feb 2025 11:43:32 +0000
FIX field incorrect 'Illegal Price'
View Count: 1406
[2021-04-07 16:51:04] |
C_Money - Posts: 70 |
Hello. I am getting this error when trying to trade 1 contract of QMK21: I contacted the broker (edge clear) and they said it is an error on the Sierra side. SC/TT Futures Order Routing order update (Order reject). Info: TT order update (Rejected). Text: FIX field incorrect 'Illegal Price: '5890.0 contract 'QMK1' (ticks in 25, CAB of 0)' | ExchID: 8031171788398 | Text: Attached order. Parent: 7627. Tag: 1-targets.twconfig. Internal Order ID: 7628. Service Order ID: 5473050. Symbol: QMK21_FUT_NYMEX. | 2021-04-07 12:21:53.694 * |
[2021-04-07 17:50:17] |
Probably you are using the Trade and Current Quote Symbol with this symbol. Set the Tick Size to .025: Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-07 18:10:51] |
Yes sir I am. Ok thanks I will try that out!
[2021-04-07 18:46:42] |
Alright, I updated it but I got the same error again. However, the trade gets placed anyway and for some reason the P/L lines don't show up or show open positions. I am trading off CLK21 and setting it so that orders are routed to QMK21. When I was on server side simulation, it would show me my open position on both CL and QM. Now it only shows on QM. Date Time Of Last Edit: 2021-04-07 18:51:16
[2021-04-08 14:41:26] |
I decided to start from 2 new intraday charts for CLK and QMK so all the chart settings are reset. I followed the instructions here for using Trade and Current Quote Symbol Price Multiplier properly: Chart Settings: Trade and Current Quote Symbol Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) On my CLK chart my Price Display Format is 0.01 and Tick Size is 0.0250000 Real-Time Price Multiplier is 0.01 Historical Price Multiplier is 0.01 Currency Value Per Tick is 10 On Advanced Settings 3 I have Trade And Current Quote Symbol Price Multiplier set to 0.001 On my QMK chart, my Price Display Format is 0.001 and Tick Size is 0.025000 Real Time Price Multiplier is 0.001 Historical Price Multiplier is 0.001 Currency Value per Tick is 12.5 What am I missing in order to trade QMK direct from my CLK chart? I'm still getting the tick size error. SC/TT Futures Order Routing order update (Order reject). Info: TT order update (Rejected). Text: FIX field incorrect 'Illegal Price: '59640.0 contract 'QMK1' (ticks in 25, CAB of 0)' | ExchID: 8031187675890 | Text: Attached order. Parent: 7641. Tag: 1-targets.twconfig. Internal Order ID: 7642. Service Order ID: 5478572. Symbol: QMK21_FUT_NYMEX.| 2021-04-08 10:26:22.951 * Date Time Of Last Edit: 2021-04-12 18:11:35
[2021-04-09 16:17:48] |
Any thoughts on this?
[2021-04-12 18:52:00] |
We are looking this over.
[2021-04-12 19:45:54] |
We have gone over this, and we have expanded upon the documentation here for exactly what to do with this symbol combination: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#UsingTradeSymbol We did do testing on a live account and there were no order rejections with the specified settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-13 02:12:55] |
Ok. I re-checked my settings and they are all correct .. I haven't yet tried it on Live but please see this screen capture I took of a SIM trade. Orders on SIM open and close instantly, and the DPL is an insane number. Then if I uncheck "Use As Trade Only Symbol", the orders don't close instantly, but there are no lines connecting the open and close price of the position. https://youtu.be/gHkB_Wo4esU See screenshot for the loss line going all the way down to $5 for QM: http://www.sierrachart.com/image.php?Image=1618281547877.png I also uploaded a trade activity log so you can see the instant closure of the trade at a price that never happened during that time frame. Date Time Of Last Edit: 2021-04-13 02:42:36
[2021-04-13 05:30:30] |
There may very well be problems with this kind of configuration with Trade Simulation Mode. We would have to analyze that. It has only been verified to work with live trading. So you cannot use this kind of configuration with Trade Simulation Mode. This is not anything we are going to support. There is already way too much complexity in this already. It is the exchange itself, which is using different multipliers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-13 05:30:52
