Date/Time: Tue, 25 Feb 2025 07:32:11 +0000
MBO
View Count: 805
[2021-04-07 16:12:32] |
User909322 - Posts: 4 |
Bonjour J'ai suivi toutes les instructions mais je n'arrive pas à connecter le mbo sur mon carnet d'ordre. Merci de votre aide. Hello I have followed all the instructions but I cannot connect the mbo to my order book. Thank you for your help. |
[2021-04-07 17:21:54] |
John - SC Support - Posts: 38150 |
You do not have any exchanges activated on the Denali Exchange Data Feed. This is why you would not be getting the MBO data. Make sure you activate the exchanges for which you want MBO data, with the Market Depth included. Make sure you go through all of the Setup Instructions for the data you want. Refer to the following for the CME Group: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* And refer to the following for EUREX: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
