Date/Time: Sat, 26 Sep 2026 00:34:23 +0000
Study settings saving
View Count: 683
| [2021-04-07 12:19:41] |
| User554446 - Posts: 29 |
Hi, I need to save some settings (volume multiplier) everytime that I come back to a ticker. I know that I can save them in the symbol settings but I would like to be more flexible and just save the last settings I set on my study on a configuration/text file since I have four different chart on the same chartbook with different Volume multiplier on the same ticker that I change two/three times a day. Is that possible? Thank you! |
| [2021-04-07 16:33:29] |
| John - SC Support - Posts: 48028 |
This is not supported for the Chart Settings. If you are looking for how to do this with the Study Inputs, then you can create a Study Collection that has the particular inputs the way you want them and load the particular Study Collection as desired. Refer to the following: Study Collections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
