Date/Time: Tue, 25 Feb 2025 06:59:35 +0000
Missing earlier days - BMF
View Count: 473
[2021-04-07 11:21:51] |
User420291 - Posts: 44 |
Good morning. My sierra stop loading BMF data for the last 2 days. I already made the delete and download data process, but didnt get any data after april,4. http://www.sierrachart.com/image.php?Image=1617793922308.png http://www.sierrachart.com/image.php?Image=1617794448989.png |
[2021-04-07 16:41:02] |
Sierra_Chart Engineering - Posts: 18554 |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Reconnect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
