Date/Time: Mon, 05 Oct 2026 01:28:40 +0000
setting scale in with OCO in attached orders
View Count: 930
| [2021-04-07 06:48:27] |
| User61576 - Posts: 458 |
I read the documentation here Attached Orders: Scaling In but didn't understand I want to up a bracket order of 2 contract: 1 contract is market order with target +8 points and stop -8 points 1 contract is a limit with an offset of 2 points from the initial market order (if I buy 4010, I want another limit at 4008 for example) with the same stop & with trial order can someone pls explain in detail with screenshots who to do so or attach a saved configuration? |
| [2021-04-08 14:24:45] |
You first need to enter your market order and then after that the Limit order. Just follow through the instructions here: Attached Orders: Scaling In Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
