Date/Time: Tue, 25 Feb 2025 07:24:47 +0000
Heat map and data feed
View Count: 871
[2021-04-07 06:37:42]
User478647 - Posts: 1
Good morning,
My broker is tradezero, I would like to get access to sierra chart to see the heat map for US stocks (nasdaq, amex, nyse). What data feed and package would I need to get? What would be the cost?
Thanks in advance.
[2021-04-07 15:48:59]
John - SC Support - Posts: 38150
Unfortunately our current data feed does not have the Level 2 depth data, so it would not work for your purposes.
We are working on a new data feed for U.S. Stocks that will have the depth data, but it is probably a month or more away.
The only choice for data at this time for Level 2 depth data is Interactive Brokers. Refer to the information here:
Interactive Brokers Trading Service
You can also look into IQ Feed, but the Market Depth data within Sierra Chart is not supported, but you can view it within the IQ Feed software. Refer to the information here:
DTN IQ Feed Data Service
