Date/Time: Fri, 07 Feb 2025 15:14:04 +0000
[Programming Help] - how to use ask-bid % in color bar based on alert condition
View Count: 633
[2021-04-07 06:25:02] |
User723500 - Posts: 23 |
been trying to color candle with using the numbers bars calculated values indicator I can get the alert build for the ask-bid difference no problem but when I try to get the the candle to color for say 14% delta for the candle it does nothing. I have tried the 14% and .14 but nothing is working. I have looked around and did not find anything that would help with the problem so if anyone has a work around that would be great. Thanks
[2021-04-09 00:13:41] |
still need some help on this, seems not data is populating for SG11 section. What is a work around?
[2021-04-09 03:16:24] |
Sawtooth - Posts: 4173 |
SG11 of the Numbers Bars Calculated Values study populates for me. Try this formula: =OR(ID5.SG11>0.14,ID5.SG11<-0.14) where the Numbers Bars Calculated Values study is ID5. |
[2021-04-09 15:05:11] |
John - SC Support - Posts: 37808 |
Refer to the following: Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
