Date/Time: Tue, 25 Feb 2025 07:22:50 +0000
Trade order Error
View Count: 708
[2021-04-06 20:35:46] |
Пользователь488020 - Posts: 100 |
Hello! When I close the terminal, I have a message of error reading the order! Tell me how to remove it and what is wrong? See the picture! https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=50011 |
[2021-04-06 20:38:28] |
John - SC Support - Posts: 38150 |
Those messages came about when you were trying to place an order. The problem is that you have defined Attached Orders along with the option for Use Attached Orders on your Trading Window, but the Total Quantity of the Attached Orders is 2, whereas your main (parent) order is only set to a quantity of 1. Therefore, you need to adjust either your main order to a quantity of 2, or the Attached Orders to a quantity of 1.
