Date/Time: Tue, 25 Feb 2025 07:39:31 +0000
still no denali feedhave AMP set up ready- Acct 82584
View Count: 618
[2021-04-06 16:52:36]
User607495 - Posts: 10
I filled out form on AMP portal for Sierra Chart- Denali-CQG ( No Data- order routing Only) AMP said you have the credentials to set me up for live trading Denali
when can you set me u?. I have done everything else.
ACCT- AC82584
[2021-04-06 17:37:10]
John - SC Support - Posts: 38150
Once you get the credentials from AMP for your CQG account, then follow these Setup Instructions to connect your Sierra Chart to CQG:
CQG Trading Platform Service: Setup Instructions
Once the above is complete, then you will want to go through the process to enable the Denali Exchange Data Feed for your Real-Time data for the CME Group. Refer to the instructions here:
And/Or refer to these instructions for the EUREX data:
https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX
Once the above is complete, then open your Chartbooks and select Edit >> Translate Symbols to Current Service in order to ensure that your symbols are using the CQG format.
