Date/Time: Tue, 25 Feb 2025 07:06:09 +0000
Data not updating live on stocks
View Count: 693
[2021-04-06 16:29:39] |
User358923 - Posts: 7 |
Hello My data is not updating live on US stocks even though I have an active subscription and enough money in my service account to renew. I just tried to load in EURUSD to see if Forex would update. Here is no problem. I had the software running for weeks with no issues. Did nothing other then usual today. |
[2021-04-06 17:27:19] |
John - SC Support - Posts: 38150 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-06 17:36:40] |
Software version: 2237 64-bit | 2021-04-06 13:34:31.108 Primary Thread ID: 17592 | 2021-04-06 13:34:31.108 Usage end date: 2021-04-23 | 2021-04-06 13:34:31.108 Enabled for: Advanced Features 2. | 2021-04-06 13:34:31.108 Enabled for: Sierra Chart Historical Data Service. | 2021-04-06 13:34:31.108 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2021-04-06 13:34:31.108 Enabled for: Delayed Denali Exchange Data Feed. | 2021-04-06 13:34:31.108 Enabled for exchange: U.S. Equities (NYSE, NASDAQ, AMEX) | 2021-04-06 13:34:31.108 Enabled for exchange: Euronext Equities Delayed | 2021-04-06 13:34:31.108 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-04-06 13:34:31.108 Current selected Data/Trading service: SC Data - All Services | 2021-04-06 13:34:31.108 Custom symbol settings values: enabled | 2021-04-06 13:34:31.108 Chart Update Interval: 500 | 2021-04-06 13:34:31.108 Intraday Data Storage Time Unit: 0 | 2021-04-06 13:34:31.108 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-04-06 13:34:31.108 2021-04-06 17:34:31 Local computer time in UTC | 2021-04-06 13:34:31.108 2021-04-06 13:34:31 Local computer time in SC Time Zone | 2021-04-06 13:34:31.108 2021-04-06 15:20:12 Server time in UTC | 2021-04-06 13:34:31.108 Local computer UTC time and Server UTC time difference: 6 seconds. | 2021-04-06 13:34:31.108 Notice: Your computer's clock is off by 6 seconds. For help with this, press the 'Send for Analysis' button. | 2021-04-06 13:34:31.108 Program path: C:\SierraChart\ | 2021-04-06 13:34:31.108 Data Files path: C:\SierraChart\Data\ | 2021-04-06 13:34:31.108 OS Version Number: 10.0 | 2021-04-06 13:34:31.108 Locale Setting: C | 2021-04-06 13:34:31.108 DLLs: TicinoMathV3.0.dll, TicinoMathV3.0_2151.dll, TicinoMathV3.0_2151_64.dll, TicinoMathV3.0_64.dll, TicinoSuite_64.dll, UserContributedStudies_64.dll | 2021-04-06 13:34:31.108 Allowed protected custom studies: TicinoMathV3.0.DLL, TicinoSuite | 2021-04-06 13:34:31.108 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-04-06 13:34:32.280 DTC Client socket (1) | Creating socket. | 2021-04-06 13:34:32.282 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-06 13:34:32.283 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-04-06 13:34:32.283 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:34:32.396 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:34:32.396 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:34:32.396 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:34:32.521 SC Data - All Services | Sending logon request message. | 2021-04-06 13:34:32.521 SC Data - All Services | Received logon response. | 2021-04-06 13:34:32.730 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:34:32.730 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:34:32.730 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:34:32.730 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:34:32.730 DTC Client socket (1) | CloseSocket call. | 2021-04-06 13:34:32.731 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:34:32.732 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:34:32.732 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:34:32.732 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-04-06 13:34:32.828 DTC Client socket (1) | Closed. | 2021-04-06 13:34:32.829 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-04-06 13:34:37.730 DTC Client socket (1) | Creating socket. | 2021-04-06 13:34:37.731 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-06 13:34:37.731 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-04-06 13:34:37.731 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:34:37.836 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:34:37.836 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:34:37.836 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:34:37.967 SC Data - All Services | Sending logon request message. | 2021-04-06 13:34:37.967 SC Data - All Services | Received logon response. | 2021-04-06 13:34:38.185 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:34:38.185 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:34:38.185 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:34:38.185 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:34:38.185 DTC Client socket (1) | CloseSocket call. | 2021-04-06 13:34:38.185 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:34:38.185 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:34:38.185 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:34:38.185 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-04-06 13:34:38.288 DTC Client socket (1) | Closed. | 2021-04-06 13:34:38.288 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-04-06 13:34:43.180 DTC Client socket (1) | Creating socket. | 2021-04-06 13:34:43.182 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-06 13:34:43.182 DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-04-06 13:34:43.182 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:34:43.290 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:34:43.290 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:34:43.291 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:34:43.487 SC Data - All Services | Sending logon request message. | 2021-04-06 13:34:43.487 SC Data - All Services | Received logon response. | 2021-04-06 13:34:43.694 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:34:43.694 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:34:43.694 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:34:43.694 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:34:43.694 DTC Client socket (1) | CloseSocket call. | 2021-04-06 13:34:43.695 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:34:43.695 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:34:43.695 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:34:43.696 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-04-06 13:34:43.795 DTC Client socket (1) | Closed. | 2021-04-06 13:34:43.795 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-04-06 13:34:48.705 DTC Client socket (1) | Creating socket. | 2021-04-06 13:34:48.707 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-06 13:34:48.707 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-04-06 13:34:48.707 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:34:48.812 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:34:48.812 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:34:48.813 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:34:48.933 SC Data - All Services | Sending logon request message. | 2021-04-06 13:34:48.933 SC Data - All Services | Received logon response. | 2021-04-06 13:34:49.153 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:34:49.153 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:34:49.153 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:34:49.153 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:34:49.153 DTC Client socket (1) | CloseSocket call. | 2021-04-06 13:34:49.153 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:34:49.153 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:34:49.153 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:34:49.153 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-04-06 13:34:49.254 DTC Client socket (1) | Closed. | 2021-04-06 13:34:49.254 File >> Disconnect selected. | 2021-04-06 13:34:51.802 DTC Client socket (0) | CloseSocket call. | 2021-04-06 13:34:51.810 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:34:51.810 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2021-04-06 13:34:51.810 DTC Client socket (2) | CloseSocket call. | 2021-04-06 13:34:51.810 SC DTC Data with Market Depth | Disconnected from the server. | 2021-04-06 13:34:51.810 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:34:51.810 SC Data - All Services | Disconnected. | 2021-04-06 13:34:51.814 SC Data - All Services | Connected to server complete. | 2021-04-06 13:34:58.872 Triggering next historical data download in queue. | 2021-04-06 13:34:58.873 Triggering next historical data download in queue. | 2021-04-06 13:34:58.873 Triggering next historical data download in queue. | 2021-04-06 13:34:58.873 Triggering next historical data download in queue. | 2021-04-06 13:34:58.873 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2021-04-06 13:34:58.873 No download requests in the queue to start downloads for. | 2021-04-06 13:34:58.883 No download requests in the queue to start downloads for. | 2021-04-06 13:34:58.883 No download requests in the queue to start downloads for. | 2021-04-06 13:34:58.883 No download requests in the queue to start downloads for. | 2021-04-06 13:34:58.883 Using Bid/Ask average for last trade price for GBPUSD | 2021-04-06 13:34:58.945 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPUSD. ID: 1 Service code: fxcm | 2021-04-06 13:34:58.945 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2021-04-06 13:34:58.945 SC DTC Data with Market Depth | Requesting security definition data for: GBPUSD. ID: 1 | 2021-04-06 13:34:58.945 Added historical Intraday data request for GBPUSD to the queue. | 2021-04-06 13:34:58.945 Intraday data recording state for symbol GBPUSD is set to download 'Pending'. | 2021-04-06 13:34:58.945 Triggering next historical data download in queue. | 2021-04-06 13:34:58.945 Delaying start of download for GBPUSD | 2021-04-06 13:34:58.953 DTC Client socket (1) | Creating socket. | 2021-04-06 13:34:58.956 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-06 13:34:58.956 DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2021-04-06 13:34:58.956 Mapping NLST to NLST. Service code: equities.us | 2021-04-06 13:34:58.972 SC Data - All Services | Starting real-time market data updates for: NLST (NLST). ID: 2 Service code: equities.us | 2021-04-06 13:34:58.972 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-04-06 13:34:58.972 SC Data - All Services | Requesting security definition data for: NLST (NLST). ID: 2 | 2021-04-06 13:34:58.972 Added historical Intraday data request for NLST to the queue. | 2021-04-06 13:34:58.972 Intraday data recording state for symbol NLST is set to download 'Pending'. | 2021-04-06 13:34:58.972 Triggering next historical data download in queue. | 2021-04-06 13:34:58.972 DTC Client socket (3) | Creating socket. | 2021-04-06 13:34:58.973 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:34:58.973 DTC Client socket (3) | Connecting to IP: 8.18.161.135. | 2021-04-06 13:34:58.974 SC DTC Data with Market Depth | Network connection to server complete. | 2021-04-06 13:34:59.071 SC DTC Data with Market Depth | Starting socket receive thread. | 2021-04-06 13:34:59.071 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:34:59.071 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:34:59.080 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:34:59.080 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:34:59.080 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:34:59.209 SC Data - All Services | Sending logon request message. | 2021-04-06 13:34:59.209 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2021-04-06 13:34:59.216 SC DTC Data with Market Depth | Sending logon request message. | 2021-04-06 13:34:59.216 Mapping TSLA to TSLA. Service code: equities.us | 2021-04-06 13:34:59.268 SC Data - All Services | Starting real-time market data updates for: TSLA (TSLA). ID: 3 Service code: equities.us | 2021-04-06 13:34:59.268 SC Data - All Services | Requesting security definition data for: TSLA (TSLA). ID: 3 | 2021-04-06 13:34:59.268 Added historical Intraday data request for TSLA to the queue. | 2021-04-06 13:34:59.268 Intraday data recording state for symbol TSLA is set to download 'Pending'. | 2021-04-06 13:34:59.268 Triggering next historical data download in queue. | 2021-04-06 13:34:59.268 Mapping ROKU to ROKU. Service code: equities.us | 2021-04-06 13:34:59.290 SC Data - All Services | Starting real-time market data updates for: ROKU (ROKU). ID: 4 Service code: equities.us | 2021-04-06 13:34:59.290 SC Data - All Services | Requesting security definition data for: ROKU (ROKU). ID: 4 | 2021-04-06 13:34:59.290 Added historical Intraday data request for ROKU to the queue. | 2021-04-06 13:34:59.290 Intraday data recording state for symbol ROKU is set to download 'Pending'. | 2021-04-06 13:34:59.290 Triggering next historical data download in queue. | 2021-04-06 13:34:59.290 SC Data - All Services | Received logon response. | 2021-04-06 13:34:59.834 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:34:59.834 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:34:59.834 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:34:59.834 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:34:59.834 DTC Client socket (3) | CloseSocket call. | 2021-04-06 13:34:59.835 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:34:59.835 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:34:59.835 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:34:59.835 SC DTC Data with Market Depth | Received logon response. | 2021-04-06 13:34:59.903 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2021-04-06 13:34:59.903 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:34:59.903 SC DTC Data with Market Depth | Successfully connected. | 2021-04-06 13:34:59.903 SC DTC Data with Market Depth | Trading is not supported. | 2021-04-06 13:34:59.903 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPUSD | 2021-04-06 13:34:59.903 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:34:59.939 DTC Client socket (3) | Closed. | 2021-04-06 13:34:59.939 SC DTC Data with Market Depth | Received security definition for symbol GBPUSD | 2021-04-06 13:35:00.119 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-04-06 13:35:04.847 DTC Client socket (3) | Creating socket. | 2021-04-06 13:35:04.848 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:35:04.848 DTC Client socket (3) | Connecting to IP: 8.18.161.133. | 2021-04-06 13:35:04.848 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:35:04.954 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:35:04.954 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:35:04.954 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:35:05.061 SC Data - All Services | Sending logon request message. | 2021-04-06 13:35:05.061 SC Data - All Services | Received logon response. | 2021-04-06 13:35:05.693 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:35:05.693 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:35:05.693 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:35:05.693 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:35:05.693 DTC Client socket (3) | CloseSocket call. | 2021-04-06 13:35:05.694 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:35:05.694 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:35:05.694 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:35:05.694 HD Request # 12 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2021-04-06 13:35:05.696 HD Request # 12 | Download start date-time: 2021-04-06 13:34:51.000000. File last date-time: 2021-04-06 13:34:51.652000 | 2021-04-06 13:35:05.697 HD Request # 12 | Using server: ds12.sierracharts.com port 10150 | 2021-04-06 13:35:05.698 Socket (4) | Creating socket. | 2021-04-06 13:35:05.737 Socket (4) | New receive buffer size: 5242880 | 2021-04-06 13:35:05.737 Socket (4) | Connecting to IP: 204.15.197.14. | 2021-04-06 13:35:05.737 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:35:05.799 DTC Client socket (3) | Closed. | 2021-04-06 13:35:05.799 HD Request # 12 | Setting DTC encoding to Binary VLS | 2021-04-06 13:35:06.003 HD Request # 12 | Sending historical data logon request message. | 2021-04-06 13:35:06.003 HD Request # 12 | Requesting Intraday data. Start date-time: 2021-04-06 13:34:51. Record interval: 0. Symbol: GBPUSD | 2021-04-06 13:35:06.601 HD Request # 12 | Decompressing data. | 2021-04-06 13:35:06.726 HD Request # 12 | Receiving Intraday data for GBPUSD starting at 2021-04-06 13:34:51.093000 | 2021-04-06 13:35:06.727 Socket (4) | CloseSocket call. | 2021-04-06 13:35:06.728 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:35:06.728 Historical data download thread signaled to stop. | 2021-04-06 13:35:06.729 HD Request # 12 | Timestamp of first Intraday data file record written: 2021-04-06 13:34:51.834000 | 2021-04-06 13:35:06.729 HD Request # 12 | Received 94 records from 2021-04-06 13:34:51.093000 to 2021-04-06 13:35:05.785000 (14.7 seconds) and wrote 86 records for GBPUSD | 2021-04-06 13:35:06.729 HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2021-04-06 17:35:05.785000 | 2021-04-06 13:35:06.734 Added 5 Time and Sales records to Intraday data file for GBPUSD after download. | 2021-04-06 13:35:06.734 HD Request # 12 | Completion time: 1s | 2021-04-06 13:35:06.739 HD Request # 12 | Intraday data download complete for GBPUSD. Unique request ID: 12 | 2021-04-06 13:35:06.739 Removing historical data download ID 12. | 2021-04-06 13:35:06.739 Real-time Intraday chart data file updates started for GBPUSD | 2021-04-06 13:35:06.739 Intraday chart data file opened for GBPUSD | 2021-04-06 13:35:06.739 HD Request # 12 | Enabling Intraday chart updating for symbol. | 2021-04-06 13:35:06.739 Triggering next historical data download in queue. | 2021-04-06 13:35:06.740 Delaying start of download for NLST | 2021-04-06 13:35:06.740 Chart #13 has tagged chart #28 for full recalculation. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:06.788 Socket (4) | Socket gracefully closed by remote side. | 2021-04-06 13:35:06.852 Socket (4) | Closed. | 2021-04-06 13:35:06.852 Chart #3 has tagged chart #4 for full recalculation. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:06.957 GBPUSD[M] 10 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:06.968 GBPUSD[M] 30 Min #28 | Performing a full recalculation because it has been tagged. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:06.988 Opened cached Intraday file: C:\SierraChart\Data\GBPUSD.scid. Thread ID: 9792 | 2021-04-06 13:35:08.259 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-04-06 13:35:10.700 DTC Client socket (3) | Creating socket. | 2021-04-06 13:35:10.703 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:35:10.703 DTC Client socket (3) | Connecting to IP: 8.18.161.135. | 2021-04-06 13:35:10.703 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:35:10.812 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:35:10.812 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:35:10.812 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:35:10.934 SC Data - All Services | Sending logon request message. | 2021-04-06 13:35:10.934 SC Data - All Services | Received logon response. | 2021-04-06 13:35:11.149 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:35:11.149 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:35:11.149 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:35:11.149 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:35:11.149 DTC Client socket (3) | CloseSocket call. | 2021-04-06 13:35:11.149 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:35:11.149 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:35:11.149 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:35:11.149 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:35:11.251 DTC Client socket (3) | Closed. | 2021-04-06 13:35:11.251 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-04-06 13:35:16.148 DTC Client socket (3) | Creating socket. | 2021-04-06 13:35:16.152 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:35:16.152 DTC Client socket (3) | Connecting to IP: 8.18.161.133. | 2021-04-06 13:35:16.152 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:35:16.265 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:35:16.265 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:35:16.265 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:35:16.397 SC Data - All Services | Sending logon request message. | 2021-04-06 13:35:16.398 SC Data - All Services | Received logon response. | 2021-04-06 13:35:16.592 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:35:16.592 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:35:16.592 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:35:16.592 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:35:16.592 DTC Client socket (3) | CloseSocket call. | 2021-04-06 13:35:16.593 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:35:16.593 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:35:16.593 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:35:16.593 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:35:16.699 DTC Client socket (3) | Closed. | 2021-04-06 13:35:16.699 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-04-06 13:35:21.588 DTC Client socket (3) | Creating socket. | 2021-04-06 13:35:21.589 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:35:21.589 DTC Client socket (3) | Connecting to IP: 8.18.161.135. | 2021-04-06 13:35:21.589 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:35:21.696 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:35:21.696 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:35:21.696 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:35:21.834 SC Data - All Services | Sending logon request message. | 2021-04-06 13:35:21.834 SC Data - All Services | Received logon response. | 2021-04-06 13:35:22.021 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:35:22.021 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:35:22.021 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:35:22.021 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:35:22.021 DTC Client socket (3) | CloseSocket call. | 2021-04-06 13:35:22.022 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:35:22.022 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:35:22.022 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:35:22.022 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:35:22.124 DTC Client socket (3) | Closed. | 2021-04-06 13:35:22.124 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-04-06 13:35:27.022 DTC Client socket (3) | Creating socket. | 2021-04-06 13:35:27.024 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:35:27.024 DTC Client socket (3) | Connecting to IP: 8.18.161.133. | 2021-04-06 13:35:27.024 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:35:27.133 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:35:27.133 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:35:27.134 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:35:27.247 SC Data - All Services | Sending logon request message. | 2021-04-06 13:35:27.247 SC Data - All Services | Received logon response. | 2021-04-06 13:35:27.466 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:35:27.466 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:35:27.466 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:35:27.466 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:35:27.466 DTC Client socket (3) | CloseSocket call. | 2021-04-06 13:35:27.467 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:35:27.467 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:35:27.467 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:35:27.467 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:35:27.568 DTC Client socket (3) | Closed. | 2021-04-06 13:35:27.568 HD Request # 13 | Downloading Intraday chart data for NLST to the file NLST.scid. Service: equities.us | 2021-04-06 13:35:29.697 HD Request # 13 | Download start date-time: 2020-10-02 13:35:29.000000. File last date-time: 2018-09-26 19:51:08.000000 | 2021-04-06 13:35:29.698 HD Request # 13 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2021-04-06 13:35:29.698 Socket (3) | Creating socket. | 2021-04-06 13:35:29.724 Socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:35:29.724 Socket (3) | Connecting to IP: 8.18.161.135. | 2021-04-06 13:35:29.724 HD Request # 13 | Setting DTC encoding to Binary VLS | 2021-04-06 13:35:29.948 HD Request # 13 | Sending historical data logon request message. | 2021-04-06 13:35:29.948 HD Request # 13 | Requesting Intraday data. Start date-time: 2020-10-02 13:35:29. Record interval: 0. Symbol: NLST | 2021-04-06 13:35:30.490 HD Request # 13 | Decompressing data. | 2021-04-06 13:35:30.598 HD Request # 13 | Receiving Intraday data for NLST starting at 2018-09-26 18:58:42.000000 | 2021-04-06 13:35:30.599 Socket (3) | CloseSocket call. | 2021-04-06 13:35:30.599 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:35:30.599 Historical data download thread signaled to stop. | 2021-04-06 13:35:30.599 HD Request # 13 | Received 18 records from 2018-09-26 18:58:42.000000 to 2018-09-26 19:51:08.000000 (52.4 minutes) and wrote 0 records for NLST | 2021-04-06 13:35:30.599 HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2018-09-26 23:51:08.000000 | 2021-04-06 13:35:30.600 HD Request # 13 | Completion time: 1s | 2021-04-06 13:35:30.601 HD Request # 13 | Intraday data download complete for NLST. Unique request ID: 13 | 2021-04-06 13:35:30.601 Removing historical data download ID 13. | 2021-04-06 13:35:30.601 Real-time Intraday chart data file updates started for NLST | 2021-04-06 13:35:30.601 Intraday chart data file opened for NLST | 2021-04-06 13:35:30.601 HD Request # 13 | Enabling Intraday chart updating for symbol. | 2021-04-06 13:35:30.601 Triggering next historical data download in queue. | 2021-04-06 13:35:30.601 HD Request # 14 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2021-04-06 13:35:30.601 HD Request # 14 | Download start date-time: 2021-04-06 11:21:14.000000. File last date-time: 2021-04-06 11:21:14.103000 | 2021-04-06 13:35:30.602 HD Request # 14 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2021-04-06 13:35:30.602 Socket (4) | Creating socket. | 2021-04-06 13:35:30.626 Socket (4) | New receive buffer size: 5242880 | 2021-04-06 13:35:30.627 Socket (4) | Connecting to IP: 8.18.161.133. | 2021-04-06 13:35:30.627 Socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:35:30.703 Socket (3) | Closed. | 2021-04-06 13:35:30.703 Chart #26 has tagged chart #23 for full recalculation. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:30.792 Chart #26 has tagged chart #25 for full recalculation. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:30.792 HD Request # 14 | Setting DTC encoding to Binary VLS | 2021-04-06 13:35:30.848 HD Request # 14 | Sending historical data logon request message. | 2021-04-06 13:35:30.848 Chart #17 has tagged chart #29 for full recalculation. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:30.961 NLST[M] 10 Min #25 | Performing a full recalculation because it has been tagged. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:30.964 NLST[M] 10 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:30.967 NLST[M] 30 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:31.271 HD Request # 14 | Requesting Intraday data. Start date-time: 2021-04-06 11:21:14. Record interval: 0. Symbol: TSLA | 2021-04-06 13:35:31.383 HD Request # 14 | Decompressing data. | 2021-04-06 13:35:31.491 HD Request # 14 | Receiving Intraday data for TSLA starting at 2021-04-06 11:21:14.103000 | 2021-04-06 13:35:31.946 Socket (4) | CloseSocket call. | 2021-04-06 13:35:32.169 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:35:32.170 Historical data download thread signaled to stop. | 2021-04-06 13:35:32.173 HD Request # 14 | Timestamp of first Intraday data file record written: 2021-04-06 11:21:14.805000 | 2021-04-06 13:35:32.174 HD Request # 14 | Received 19054 records from 2021-04-06 11:21:14.103000 to 2021-04-06 13:35:28.448000 (2.2 hours) and wrote 19053 records for TSLA | 2021-04-06 13:35:32.175 HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2021-04-06 17:35:28.448000 | 2021-04-06 13:35:32.180 HD Request # 14 | Completion time: 2s | 2021-04-06 13:35:32.181 HD Request # 14 | Intraday data download complete for TSLA. Unique request ID: 14 | 2021-04-06 13:35:32.181 Removing historical data download ID 14. | 2021-04-06 13:35:32.181 Real-time Intraday chart data file updates started for TSLA | 2021-04-06 13:35:32.181 Intraday chart data file opened for TSLA | 2021-04-06 13:35:32.181 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2021-04-06 13:35:32.181 Triggering next historical data download in queue. | 2021-04-06 13:35:32.181 HD Request # 15 | Downloading Intraday chart data for ROKU to the file ROKU.scid. Service: equities.us | 2021-04-06 13:35:32.182 HD Request # 15 | Download start date-time: 2021-04-06 11:21:09.000000. File last date-time: 2021-04-06 11:21:09.288000 | 2021-04-06 13:35:32.183 HD Request # 15 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2021-04-06 13:35:32.183 Socket (3) | Creating socket. | 2021-04-06 13:35:32.184 Socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:35:32.184 Socket (3) | Connecting to IP: 8.18.161.135. | 2021-04-06 13:35:32.184 Socket (4) | Socket gracefully closed by remote side. | 2021-04-06 13:35:32.274 Socket (4) | Closed. | 2021-04-06 13:35:32.274 Chart #14 has tagged chart #22 for full recalculation. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:32.306 TSLA[M] 10 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:32.333 Chart #10 has tagged chart #27 for full recalculation. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:32.362 HD Request # 15 | Setting DTC encoding to Binary VLS | 2021-04-06 13:35:32.404 HD Request # 15 | Sending historical data logon request message. | 2021-04-06 13:35:32.404 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-04-06 13:35:32.466 DTC Client socket (4) | Creating socket. | 2021-04-06 13:35:32.470 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-04-06 13:35:32.470 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-04-06 13:35:32.470 HD Request # 15 | Requesting Intraday data. Start date-time: 2021-04-06 11:21:09. Record interval: 0. Symbol: ROKU | 2021-04-06 13:35:32.510 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:35:32.580 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:35:32.580 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:35:32.580 HD Request # 15 | Decompressing data. | 2021-04-06 13:35:32.617 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:35:32.714 SC Data - All Services | Sending logon request message. | 2021-04-06 13:35:32.714 TSLA[M] 30 Min #27 | Performing a full recalculation because it has been tagged. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:32.761 HD Request # 15 | Receiving Intraday data for ROKU starting at 2021-04-06 11:21:09.288000 | 2021-04-06 13:35:32.948 Socket (3) | CloseSocket call. | 2021-04-06 13:35:32.949 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:35:32.949 Historical data download thread signaled to stop. | 2021-04-06 13:35:32.949 HD Request # 15 | Timestamp of first Intraday data file record written: 2021-04-06 11:21:18.760000 | 2021-04-06 13:35:32.949 HD Request # 15 | Received 4708 records from 2021-04-06 11:21:09.288000 to 2021-04-06 13:35:26.339000 (2.2 hours) and wrote 4707 records for ROKU | 2021-04-06 13:35:32.949 HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2021-04-06 17:35:26.339000 | 2021-04-06 13:35:32.951 HD Request # 15 | Completion time: 0s | 2021-04-06 13:35:32.951 HD Request # 15 | Intraday data download complete for ROKU. Unique request ID: 15 | 2021-04-06 13:35:32.951 Removing historical data download ID 15. | 2021-04-06 13:35:32.951 Real-time Intraday chart data file updates started for ROKU | 2021-04-06 13:35:32.951 Intraday chart data file opened for ROKU | 2021-04-06 13:35:32.951 HD Request # 15 | Enabling Intraday chart updating for symbol. | 2021-04-06 13:35:32.951 Triggering next historical data download in queue. | 2021-04-06 13:35:32.951 No download requests in the queue to start downloads for. | 2021-04-06 13:35:32.951 Socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:35:33.053 Socket (3) | Closed. | 2021-04-06 13:35:33.054 Chart #19 has tagged chart #30 for full recalculation. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:33.265 ROKU[M] 30 Min #30 | Performing a full recalculation because it has been tagged. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:33.271 Chart #20 has tagged chart #24 for full recalculation. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:33.291 ROKU[M] 10 Min #24 | Performing a full recalculation because it has been tagged. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:33.293 Chart #24 has tagged chart #18 for full recalculation. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:33.301 SC Data - All Services | Received logon response. | 2021-04-06 13:35:33.352 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:35:33.352 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:35:33.352 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:35:33.352 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:35:33.352 DTC Client socket (4) | CloseSocket call. | 2021-04-06 13:35:33.353 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:35:33.353 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:35:33.353 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:35:33.353 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-04-06 13:35:33.459 DTC Client socket (4) | Closed. | 2021-04-06 13:35:33.460 ROKU[M] 10 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: casper_bigcaps.Cht | 2021-04-06 13:35:33.763 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-04-06 13:35:38.354 DTC Client socket (3) | Creating socket. | 2021-04-06 13:35:38.356 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:35:38.356 DTC Client socket (3) | Connecting to IP: 8.18.161.133. | 2021-04-06 13:35:38.356 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:35:38.465 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:35:38.465 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:35:38.465 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:35:38.582 SC Data - All Services | Sending logon request message. | 2021-04-06 13:35:38.582 SC Data - All Services | Received logon response. | 2021-04-06 13:35:39.223 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:35:39.223 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:35:39.223 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:35:39.223 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:35:39.223 DTC Client socket (3) | CloseSocket call. | 2021-04-06 13:35:39.224 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:35:39.224 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:35:39.224 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:35:39.224 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:35:39.329 DTC Client socket (3) | Closed. | 2021-04-06 13:35:39.329 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-04-06 13:35:44.210 DTC Client socket (3) | Creating socket. | 2021-04-06 13:35:44.213 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:35:44.213 DTC Client socket (3) | Connecting to IP: 8.18.161.135. | 2021-04-06 13:35:44.213 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:35:44.320 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:35:44.320 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:35:44.320 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:35:44.434 SC Data - All Services | Sending logon request message. | 2021-04-06 13:35:44.434 SC Data - All Services | Received logon response. | 2021-04-06 13:35:44.634 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:35:44.634 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:35:44.634 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:35:44.634 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:35:44.634 DTC Client socket (3) | CloseSocket call. | 2021-04-06 13:35:44.635 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:35:44.635 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:35:44.635 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:35:44.635 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:35:44.741 DTC Client socket (3) | Closed. | 2021-04-06 13:35:44.741 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-04-06 13:35:49.646 DTC Client socket (3) | Creating socket. | 2021-04-06 13:35:49.651 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:35:49.651 DTC Client socket (3) | Connecting to IP: 8.18.161.133. | 2021-04-06 13:35:49.651 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:35:49.774 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:35:49.774 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:35:49.774 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:35:49.916 SC Data - All Services | Sending logon request message. | 2021-04-06 13:35:49.916 SC Data - All Services | Received logon response. | 2021-04-06 13:35:50.120 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:35:50.120 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:35:50.120 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:35:50.120 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:35:50.120 DTC Client socket (3) | CloseSocket call. | 2021-04-06 13:35:50.121 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:35:50.121 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:35:50.121 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:35:50.121 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:35:50.226 DTC Client socket (3) | Closed. | 2021-04-06 13:35:50.226 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-04-06 13:35:55.126 DTC Client socket (3) | Creating socket. | 2021-04-06 13:35:55.129 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:35:55.129 DTC Client socket (3) | Connecting to IP: 8.18.161.135. | 2021-04-06 13:35:55.129 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:35:55.237 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:35:55.237 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:35:55.237 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:35:55.372 SC Data - All Services | Sending logon request message. | 2021-04-06 13:35:55.372 SC Data - All Services | Received logon response. | 2021-04-06 13:35:55.585 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:35:55.585 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:35:55.585 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:35:55.585 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:35:55.585 DTC Client socket (3) | CloseSocket call. | 2021-04-06 13:35:55.585 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:35:55.585 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:35:55.585 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:35:55.585 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:35:55.688 DTC Client socket (3) | Closed. | 2021-04-06 13:35:55.688 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-04-06 13:36:00.598 DTC Client socket (3) | Creating socket. | 2021-04-06 13:36:00.599 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:36:00.599 DTC Client socket (3) | Connecting to IP: 8.18.161.133. | 2021-04-06 13:36:00.599 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:36:00.709 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:36:00.709 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:36:00.709 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:36:00.829 SC Data - All Services | Sending logon request message. | 2021-04-06 13:36:00.829 SC Data - All Services | Received logon response. | 2021-04-06 13:36:01.032 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:36:01.032 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:36:01.032 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:36:01.032 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:36:01.032 DTC Client socket (3) | CloseSocket call. | 2021-04-06 13:36:01.032 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:36:01.032 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:36:01.032 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:36:01.033 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:36:01.134 DTC Client socket (3) | Closed. | 2021-04-06 13:36:01.134 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-04-06 13:36:06.025 DTC Client socket (3) | Creating socket. | 2021-04-06 13:36:06.026 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:36:06.026 DTC Client socket (3) | Connecting to IP: 8.18.161.135. | 2021-04-06 13:36:06.026 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:36:06.132 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:36:06.132 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:36:06.132 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:36:06.242 SC Data - All Services | Sending logon request message. | 2021-04-06 13:36:06.242 SC Data - All Services | Received logon response. | 2021-04-06 13:36:06.866 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:36:06.866 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:36:06.866 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:36:06.866 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:36:06.866 DTC Client socket (3) | CloseSocket call. | 2021-04-06 13:36:06.866 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:36:06.866 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:36:06.866 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:36:06.866 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:36:06.971 DTC Client socket (3) | Closed. | 2021-04-06 13:36:06.971 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2021-04-06 13:36:11.869 DTC Client socket (3) | Creating socket. | 2021-04-06 13:36:11.873 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-04-06 13:36:11.873 DTC Client socket (3) | Connecting to IP: 8.18.161.133. | 2021-04-06 13:36:11.873 SC Data - All Services | Network connection to server complete. | 2021-04-06 13:36:11.979 SC Data - All Services | Starting socket receive thread. | 2021-04-06 13:36:11.979 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-06 13:36:11.980 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-06 13:36:12.094 SC Data - All Services | Sending logon request message. | 2021-04-06 13:36:12.094 SC Data - All Services | Received logon response. | 2021-04-06 13:36:12.720 SC Data - All Services | Server Name: SC Real-Time Server. | 2021-04-06 13:36:12.720 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-06 13:36:12.720 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:36:12.720 SC Data - All Services | Waiting for socket receive thread to end | 2021-04-06 13:36:12.720 DTC Client socket (3) | CloseSocket call. | 2021-04-06 13:36:12.720 SC Data - All Services | Disconnected from the server. | 2021-04-06 13:36:12.720 SC Data - All Services | Data feed disconnected. Will reconnect in 5 seconds. | 2021-04-06 13:36:12.720 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-06 13:36:12.720 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-04-06 13:36:12.824 DTC Client socket (3) | Closed. | 2021-04-06 13:36:12.825 |
[2021-04-06 17:39:13] |
The following is the issue: SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-04-06 13:34:32.730
You are trying to access the Stock data from a second computer when you already have a connection running on a different computer. You can only have 1 connection at a time to the Sierra Chart Exchange Data Feed. Therefore, you would have to be sure you are disconnected from the data feed on the one system (or exit completely from Sierra Chart) before you can connect on the other computer. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-06 17:47:27] |
Thank you for your prompt reply. Can I subscribe to the Sierra Chart Exchange Data Feed so I can use two computers at the same time with the same Sierra login?
[2021-04-06 20:12:25] |
Unfortunately, no, what you want to do is not possible with the way the Sierra Chart Exchange Data Feed is setup. The option that is currently available would be to create a second Sierra Chart account and set it up with the Sierra Chart Exchange Data Feed again. As you can guess, this gets a bit pricey. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-06 20:14:42
