Date/Time: Wed, 12 Mar 2025 11:50:33 +0000
Sierra Charts AMP Futures connection using Denali Data Feed
View Count: 3184
[2021-04-06 16:29:22] |
h0408365 - Posts: 14 |
What steps do I need to take to connect my AMP account to Sierra using Sierra's Denali Data Feed? I can't find this information anywhere. I Contacted AMP, they had me fill out a form for connection and they said I would have to contact Sierra to figure out when the connection will be made. |
[2021-04-06 17:25:52] |
John - SC Support - Posts: 38598 |
Most likely AMP set you up with CQG for your order routing. If so, then follow these instructions to connect your Sierra Chart to CQG: CQG Trading Platform Service: Setup Instructions Then go through these procedures to ensure that you are setup to get your data through the Denali Exchange Data Feed: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services And finally, open your Chartbooks and select Edit >> Translate Symbols to Current Service. This will change your symbols to the CQG symbols. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-02 13:11:29] |
User323293 - Posts: 3 |
Hello Could you please help me to connect my Sierra Chart to denali data? I got this error message: Connection error message from service: Rithmic Trading | Logon error received from server | Data - time : 2021-09-02 Best regards Wassim |
[2021-09-02 16:20:05] |
You are already setup to use the Denali Exchange Data Feed and you have the "CME with Market Depth for NonProfessionals" exchange active. So there should not be anything else you need to do with this, unless you need data for other exchanges within the CME Group, in which case you can adjust the exchanges you have active on this page: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges Connection error message from service: Rithmic Trading | Logon error received from server | Data - time : 2021-09-02
That message has nothing to do with the Denali Exchange Data Feed. It is from Rithmic, telling you that you have a logon error. Check your settings in File >> Data/Trade Service Settings and make sure you have the correct Username and Password entered. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-03 06:47:44] |
User636954 - Posts: 1 |
What steps do I need to take to connect my AMP account to Sierra using Sierra's Denali Data Feed? I follow your instructions but still cannot connect I currently can connect to CQG WebAPI and Denali Exchange Data Feed separately but I cannot do both, ie placing live trade order using Denali data. In Data/Trade Services Settings, main settings, I choose cqg webapi and successfully connect and In Data/Trade Services Settings, common settings, I choose allow support for Sierra Chart data feeds, Yes In Edit, I click Translate Symbols to Current Service I disconnect and reconnect again I still cannot see denali data, eg. only top of the book, no letter m etc please help thank you |
[2022-03-03 15:05:24] |
User636954: You need to activate the exchanges for which you want the CME Group data. You can do this at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges After you activate the exchange, then you should be getting the Denali data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-11 11:29:21] |
edwinRSISP - Posts: 3 |
Hi, any reply to this? I am facing the same problem. I do not have the "Denali Data Feed" showing only "CQG WebAPI" Thank you What steps do I need to take to connect my AMP account to Sierra using Sierra's Denali Data Feed? I follow your instructions but still cannot connect
I currently can connect to CQG WebAPI and Denali Exchange Data Feed separately but I cannot do both, ie placing live trade order using Denali data. In Data/Trade Services Settings, main settings, I choose cqg webapi and successfully connect and In Data/Trade Services Settings, common settings, I choose allow support for Sierra Chart data feeds, Yes In Edit, I click Translate Symbols to Current Service I disconnect and reconnect again I still cannot see denali data, eg. only top of the book, no letter m etc please help thank you Date Time Of Last Edit: 2022-05-11 11:30:01
[2022-05-11 11:37:32] |
.... i read here Denali Exchange Data Feed "7.If you will be using the Denali Exchange Data Feed independent of and not integrated with any particular supported Trading service, then select Global Settings >> Data/Trade Service Settings and set the Service to SC Data - All Services." An hour ago it was showing "delayed" on my charts...now the "delayed" is no longer there. Hope this helps everyone who are searching. Just one last question -> Does "SC Data" means it is DEnali ? Thank you |
[2022-05-11 11:48:55] |
I just read on web that SC Data is not Denali. hope someone can help here. I only could choose SC Data or CQGwebAPI .... could not find Denali in the drop down list |
Attachment Deleted. ![]() |
