Date/Time: Tue, 25 Feb 2025 07:26:26 +0000
Switching Brokers
View Count: 549
[2021-04-06 16:23:49]
User185631 - Posts: 12
Hi, I recently funded an account with Edge Clear and will be closing my Account with AMP. What do I need to do to have this change updated in my SC? Thanks!
[2021-04-06 16:27:25]
John - SC Support - Posts: 38150
Are you using the Sierra Chart Order Routing Service with Edge Clear? If so, then you would be following these Setup Instructions:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
Everything you need to do is in those Setup Instructions. Just go through them completely and you will be setup.
