Date/Time: Tue, 25 Feb 2025 07:30:00 +0000
flux
View Count: 591
[2021-04-06 16:06:52] |
User338651 - Posts: 14 |
comment faire pour avoir un flux de donné pour simulation cordialement |
[2021-04-06 16:16:15] |
John - SC Support - Posts: 38150 |
From Google Translate: how to have a data flow for simulation
cordially If you are not doing live trading, then we recommend using the Delayed Data Feed, which includes data from the CME Group and EUREX. Refer to the information here: Delayed Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
