Date/Time: Wed, 27 Nov 2024 19:45:10 +0000
Modifying An Existing Stop Order to a New Trailing Stop Order
View Count: 1610
[2021-04-06 15:23:45]
lvlupfinance - Posts: 3
I would like to know how to quickly change my existing stop order to a new trailing stop order. For example: I enter into a position with a 10 tick initial stop and then after the contracts have moved up 10 ticks I want a new stop order to be trailing at 12 ticks. Additionally, if there is a way to do this while simultaneously cancelling the initial stop order that would be helpful. Thank you.
[2021-04-06 15:57:23]
John - SC Support - Posts: 36344
Why not just use the Triggered Trailing Stop order type?
Refer to the following:
Order Types: Triggered Trailing Stop
[2021-04-06 18:49:36]
Thank you very much for the reply, that is essentially the tool I needed. However, I'm wondering if there is a way to manually alter a stop order when its in place. I know you can alter the stop price, but can you change it to a trail stop? Can you increase the distance of the trailing stop once it's placed? Whenever I manually drag a trailing stop it then returns to the original distance once the price moves. I appreciate the help.
[2021-04-07 08:56:10]
No.
Yes. Refer to:
Global Trade Settings Windows: Adjust Trail Offset When Modifying Trail Order (Global Settings >> Chart Trade Settings >> General >> Order Entry)
[2021-04-07 15:28:37]
User476926 - Posts: 56
Yes you can do this, it is one of the essential features I use.
You just have to define your regular trailing stop distances, for sake of example let's say 6 Ticks and 12 Ticks (or a moving average line).
Add to Control Bar two custom buttons:
Customize Control Bar > Advanced Custom Study Button > ACS 1 and ACS2
Label one button "6T" and label the other "12T"
Under studies in chart window, you then need to add:
"Trade Management by Study" - twice (one for 6T and one for 12T).
"Current Price Line" study.
In Trade Management by Study select:
Order type: Stops
Controlling Subgraph: this is your "Current Price Line" study
Trailing offset (Ticks): 6
ACS Control Bar button: 1 (this links to button 6T)
Only modify stops in one direction: Yes
Order adjustment timing: select either N seconds or close of bar
Repeat for second Trade Management by Study but use:
Trailing offset (Ticks): 12
ACS Control Bar button: 2
You need to have the chart window that includes Trade Management by Study selected, but you can now "single click" on either of your 2 control bar buttons and it will update the fixed stop to either 6 or 12 ticks behind Current Price. This will then continue to trail and update based on your selection in Trade Management of either N seconds or on bar close.
[2023-07-06 20:34:11]
Technical - Posts: 158
Also, check Trade>>Auto Trading Enabled-Global
