Date/Time: Thu, 19 Sep 2024 21:41:00 +0000
TT feed new market stats symbol
View Count: 1131
[2014-03-06 04:35:10] |
toews&kane - Posts: 209 |
When I try to update my $TICK for example to TICK-NYSE it says symbol unknown
[2014-03-06 04:41:20] |
Update to the latest Prerelease by following these instructions: https://www.sierrachart.com/index.php?l=doc/download.php#FastUpdate After the update, your chart will be automatically converted without having to do anything special. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-06 05:07:18] |
Odd the $TRIN and TRIN-NYSE should be the same no? on 3-3-2014 it has different values just checking the open doesn't match |
[2014-03-06 17:34:15] |
There can be some differences. The calculations are described here: http://www.sierrachart.com/index.php?l=doc/SCMarketStatistics.php#CalculationsAlgorithms Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
