Date/Time: Tue, 25 Feb 2025 05:37:41 +0000
Historical Market Depth DOM
View Count: 743
[2021-04-04 21:57:18]
User548030 - Posts: 25
As the title suggests, I'm trying to replay the DOM ladder from last week with market depth. I have not recorder the market depth. Is it possible to fetch the historical market depth data?
[2021-04-05 02:49:22]
Yes. Refer to:
Market Depth Historical Graph: Downloading Of Historical Market Depth Data
[2021-04-05 03:27:39]
Thank you, I see those are instructions for the chart. I'm using a DOM. I followed the steps but I cannot add the study to the DOM.
Thanks.
[2021-04-05 16:16:03]
John - SC Support - Posts: 38150
You would really need to open a chart for the same symbol and then ensure that you have the depth data back to where you want in order to replay the Trading DOM.
