Date/Time: Tue, 25 Feb 2025 14:17:25 +0000
Count down timer not showing up on chart
View Count: 668
[2021-04-04 19:13:15]
User262667 - Posts: 36
The "Count down timer study" is not showing up on my screen? Please tell me what setting I need to have it show up?
[2021-04-05 15:38:00]
John - SC Support - Posts: 38150
This should not happen. Make sure you remove all versions of the study from the chart and then add a new copy of the study.
When you add the new study, set the Initial Horizontal Position and Initial Vertical Position to values of 50 each. This will place the Countdown Timer near the center of the chart. Refer to the following:
Countdown Timer: Inputs
Let us know if you still have an issue after this.
[2021-04-16 15:31:14]
You may also need to remove instances of the Countdown Timer text through the Tools >> Manage Chart Drawings Window.
Date Time Of Last Edit: 2021-04-16 15:31:28
