Date/Time: Tue, 25 Feb 2025 11:37:49 +0000
Accessing symbol from s_UseTool
View Count: 661
[2021-04-04 17:09:55] |
SviCh - Posts: 40 |
s_UseTool class does not contain symbol information. Though it's clear that every chart drawing has it's own symbol assigned, as we can see in Manage Chart Drawings Window. Is there any way to access that information programmatically ? |
[2021-04-06 23:43:47] |
SviCh - Posts: 40 |
This is ACSIL question, related to https://www.sierrachart.com/index.php?l=doc/ACSILDrawingTools.html#scGetUserDrawnDrawingByLineNumber
[2021-04-13 14:54:44] |
We will add the symbol if it does not already exist in the data structure.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-13 14:54:56
[2021-04-13 15:04:12] |
This will be out in the next release.
