Date/Time: Tue, 25 Feb 2025 07:32:23 +0000
linking my laptop to desktop
View Count: 740
[2021-04-03 16:40:59] |
GaryMac - Posts: 18 |
hi there,,, is there a way of linking all my laptop charts on to my new desktop as when I'm logging in to my desktop my account is starting a fresh
[2021-04-05 14:21:11] |
John - SC Support - Posts: 38150 |
Refer to the following for how to copy from one installation to a new one: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation If you are working on one and then moving to the other from time to time, and you want to update the Chartbooks between systems, then you can copy the Chartbooks between them, but you just need to ensure that you do so when Sierra Chart is not running on either system. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-07 05:40:23] |
also is there a new window for data/trade time zones as i cant change it on my computer its a different window from your website
[2021-04-07 14:16:58] |
Yes, there is a new window for the Time Zones. You can access the Time Zone Settings window from Global Settings >> Time Zone Settings. Refer to the following for how to work with the new windows: Settings Windows Interface For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
