Date/Time: Tue, 25 Feb 2025 04:01:27 +0000
Issue will rollover calculations for version 2245
View Count: 517
[2021-04-03 14:59:59]
User45989 - Posts: 54
Issue can be seen when viewing symbol FGBLM21-EUREX in range between Feb 10th through March 5th, 2021. You will see stray entries approximately 3pts below the rest of the price action (so 171 would be ~168)
Continuous contract settings are set to "Date Rule Rollover, Back Adjusted".
Also tested on 2239 and same issue is seen.
Let me know if you require further information. Screenshot attached.
imageScreenshot 2021-04-03 085825.png / V - Attached On 2021-04-03 14:58:47 UTC - Size: 52.07 KB - 203 views
[2021-04-03 15:39:54]
I believe that this issue was introduced this month and may have something to do with the new data. I double checked some data that I had downloaded from a month ago and the problem did not exist. I have copies of both of the new FGBL daily/1min files if you would like to review the differences.
Private File
Private File
[2021-04-04 00:25:49]
There is something wrong with the data that you have. Notice how the data is repeating when you look at the dates. This is what we see:
http://www.sierrachart.com/image.php?Image=1617495917561.png
Follow the instructions here:
Date Time Of Last Edit: 2021-04-04 00:26:09
