Date/Time: Tue, 25 Feb 2025 04:13:38 +0000
Relative Volume High and Low Percent Threshold enhancement request
View Count: 537
[2021-04-03 12:38:56]
User283714 - Posts: 3
Dear Support Agent,
I would like to ask for an enhancement to the Relative Volume study, which will improve its use and effectiveness.
The enhancements is to add a standard deviation capability for the High Threshold Percent (and also Low but High Threshold is more important)
Instead of just inputting a % number to trigger the signal, it is improved if we can put in a standard deviation over the number of days.
In other words to show the relative volume in excess of a standard deviation(s) of the relative volumes over the x number of days.
This will really improve the usage of the tool. This is a great tool but can even become better.
Thank you,
John
