Date/Time: Tue, 25 Feb 2025 04:21:52 +0000
sccolors.h has duplicate RGB codes
View Count: 477
[2021-04-03 01:31:59] |
TriStar Trading - Posts: 148 |
While coding today and using color constants I came across COLOR_GREEN = RGB(0,255,0); and COLOR_LIME = RGB(0,255,0);.I believe the Lime code is correct but Green is 0,128,0 on the HTML Codes site I have. Thanks
[2021-04-03 03:00:39] |
We will get this cleaned up.
