Date/Time: Tue, 25 Feb 2025 03:57:49 +0000
AMP
View Count: 729
[2021-04-02 23:35:27] |
Oxcap - Posts: 73 |
Hi, I read through the thread regarding removal of TT Trading accounts. Since my trading account from AMP has been removed, what is the quickest solution to receive real-time data now since I am currently on delayed data? I have also tried to follow your steps by connecting to SC Data - All Services, but I was already connected to this when under AMP. I have a Tradovate account with Dorman. Would I be simply be able to use my login/password that I use with Tradovate here? Thanks, |
[2021-04-03 03:06:42] |
You really have to follow through the instructions here: TT Based Order Routing Service: TT Interruption | Post: 252374 You only need to connect to the CQG system once a month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-03 03:08:06
