Date/Time: Tue, 25 Feb 2025 04:26:24 +0000
cup with handle studie
View Count: 528
[2021-04-02 15:51:26] |
User453589 - Posts: 4 |
Hello. Is there an indicator to find the "cup with handle" on DJ or SP500? Thanks! |
[2021-04-02 16:13:16] |
John - SC Support - Posts: 38150 |
The "cup with handle" is not specifically called out, but take a look through the Candle Stick Pattern Finder study to see if any of what is available may be close to what you are looking for: CandleStick Patterns Finder: Available Patterns The code for the Candle Stick Pattern Finder is available and is in Studies4.cpp, so you can modify or add to the study for what you want as well. Refer to the following: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
