Date/Time: Tue, 25 Feb 2025 04:26:35 +0000
show yesterdays pivot points today
View Count: 587
[2021-04-02 09:02:26]
UserOne - Posts: 40
I like to show yesterdays and the day before yesterdays pivot points on the today chart.
There is no Reference Days Back nor extend line for 2 days.
Any suggestion how to accomplish this task?
[2021-04-02 14:40:34]
John - SC Support - Posts: 38150
You could use the Displacement option and move the Pivot Points subgraphs forward, but it does come with the issue that whenever there is a day that does not have the same number of bars as a typical day (such as today, Good Friday), then you would have adjust for this. Refer to the following:
Chart Studies: Subgraphs Tab >> Displacement
A more consistent way would be to use the Spreadsheet Study and use an IF statement to check the date and look for the previous day. You would have to get a bit creative with Mondays, but it can be done. Refer to the following:
Using the Spreadsheet Study: Step By Step Instructions to use the Spreadsheet Study
