Date/Time: Sun, 13 Sep 2026 19:24:48 +0000
H1 countdown bar timer is diferent bettwen two charts
View Count: 702
| [2021-04-01 18:56:36] |
| User553932 - Posts: 2 |
Hi, I've found a big difference bettween countdown bar timer in two diferent H1 charts. All Time zones has the same configuration and this difference doesn't exists between another time frame charts ( 5 MIn for instance). The bar timer count is 15:30 in 60 Min ES chart and 30:30 in 60 Min MNQ chart. How is it possible? (all charts has same confgiration and Data provides is SC from Denali Datafeed adquired pack) Thanks, |
| [2021-04-01 19:31:56] |
| John - SC Support - Posts: 47854 |
We are not sure we understand exactly what the issue is. If you are stating that you have 2 different 1 hour charts and one shows 15:30 for the Countdown Timer on that chart and another shows 30:30 for the Countdown Timer on that chart, then this would be caused by differences in the Session Time Start Times. Refer to the following: Chart Session Times: Bar Starting Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
