Date/Time: Tue, 25 Feb 2025 04:27:39 +0000
Change to Pro-Certification
View Count: 444
[2021-04-01 18:07:17] |
User755412 - Posts: 14 |
I am having trouble accessing the necessary agreements to certify as a professional so I can purchase data directly from the exchanges. Can you send me a link to the agreement I need to change / update and instruction on how to do so? Thank you.
[2021-04-01 19:05:08] |
John - SC Support - Posts: 38150 |
The agreements are on the following page. You will need to complete both of the agreements under the Real-Time Data Agreements section again. https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
