Date/Time: Mon, 25 Nov 2024 21:43:27 +0000
Tape & number of trade .
View Count: 2791
[2014-03-05 19:31:07] |
bronson - Posts: 14 |
hello , see the sreen below : [IMG]http://img15.hostingpics.net/pics/267318DOMtapedax.jpg[/IMG][/URL] Look at the number of trade : thre are only : 1...1....1....1.....1 so there is a matter , it's impossible . I have verified on other instruments like ES or YM : it's the same problem . it doesn't work . Can you examinate the problem please ? And i would like ask to you too, if it would possible to see our place in the queue and the number of trader before and behind us like the DOM of scalptool or the DOM of s x-trader. see the screen below : We can see that i've 35 traders before me and 2 behind me [IMG]http://img11.hostingpics.net/pics/605437queuescalptool.png[/IMG][/URL] Thanks a lots best regards . Date Time Of Last Edit: 2014-03-05 19:32:01
[2014-03-05 20:00:20] |
The Number Trades for every trade within the Time and Sales window will be 1. This is normal.
[2014-03-05 22:36:10] |
i would like to see in the tape , when 50 contracts (for example) are traded at the ask, then how there are trader behind these 50 contracts, 1, 10, 20? And for the rest of my question ( place in the queue, number of trader before and behind me ....) Thanks ! Date Time Of Last Edit: 2014-03-05 22:43:11
[2014-03-06 05:06:23] |
A trade of 50 contracts means there is both a buyer and a seller matched at 50 contracts. The other request will be considered in the longer-term. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-06 06:01:59] |
TradingMarketProfile - Posts: 120 |
Hello, the thing he want to know is for exemple there is 50 contrats at the Bid,he want to know how many order for that 50 contrats ( 1 trader x50 or 50 trader x 1 or else).. is it possible for you to add the option ? as you can see on the picture, there is 2 colomns at the Bid and at the Ask, . |
number.PNG / V - Attached On 2014-03-06 06:01:54 UTC - Size: 18.97 KB - 572 views |
[2014-03-06 18:55:12] |
No. This cannot be determined with any reliability and we will not try to do that.
