Date/Time: Tue, 25 Feb 2025 04:14:01 +0000
New set up with sierra chart
View Count: 508
[2021-04-01 16:17:50] |
Usernezpat - Posts: 4 |
I had an account with AMP and CQG (ac 85056) but now I have changed to Dorman with CQG for Sierra chart. How do i proceed to create this new account connection and i guess now i settle with you directly the fee of using the platform. Thanks for comments Patrick |
[2021-04-01 16:19:40] |
By the way would like to keep same credential since i have studies that are supplied under that account with sierra chart.
[2021-04-01 18:29:53] |
John - SC Support - Posts: 38150 |
That is not a problem. Just continue to use the same Account Name that you already have. Really, the only thing that should have to change would be the CQG Username and Password on the Data/Trade Service Settings Window. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
