Date/Time: Tue, 25 Feb 2025 04:45:14 +0000
start account
View Count: 414
[2021-04-01 16:03:29]
User267133 - Posts: 1
I am trying to open an account. I do not believe I had a direct account with you but did use your charts through Infinty Futures. Do I just make a payment to you in order to get started?
[2021-04-01 17:55:50]
John - SC Support - Posts: 38150
Did you use your Sierra Chart with Infinity Futures at all in the past month?
If so, then you should just continue to use the Sierra Chart account that was created for you by Infinity Futures.
Otherwise, are you still using Infinity Futures for your broker?
