Date/Time: Mon, 25 Nov 2024 18:43:46 +0000
Patsystems
View Count: 1460
[2014-03-05 18:42:12] |
User51517 - Posts: 58 |
Hello Support, does SC have any plans to offer Patsystems as a trading/data option? Thank you |
[2014-03-05 19:33:46] |
Never. PATS system produces unreliable software and has very unaccommodative working arrangements. Can't imagine why anyone would work with them. Also, their FIX interface is very unimpressive. It uses a persistent type of model. which makes it very hard to work with and has aspects which does not make it reliable. All of the other FIX interfaces we work with are not like it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-05 19:53:41
