Date/Time: Sat, 28 Sep 2024 01:14:12 +0000
Number of systems
View Count: 513
[2021-04-01 07:48:23] |
Luke - Posts: 142 |
I currently have Denali/CME set to 2 systems. I want to add Eurex, but only for 1 system, is that possible? Does the number of systems I choose automatically apply to all activated exchanges?
Date Time Of Last Edit: 2021-04-01 08:34:33
[2021-04-01 14:53:20] |
John - SC Support - Posts: 34775 |
The setting for the number of systems for the Denali Exchange Data Feed does apply to ALL exchanges that are active on the Denali Exchange Data Feed.
[2021-04-14 03:15:00] |
We would have to look into adding support for what you want. We will work on this.
