Date/Time: Tue, 25 Feb 2025 01:35:02 +0000
Diagonal coloring on Volume Profile.
View Count: 507
[2021-03-31 15:33:38]
User339484 - Posts: 71
I do not understand why 646 x 343 is green.
The bid ask spread to current and above is 228
The ask bid spread to current and below is -309
That looks like the dominant is negative, but the color is green.
imagediagonal.png / V - Attached On 2021-03-31 15:31:15 UTC - Size: 76.79 KB - 177 views
[2021-03-31 19:52:34]
John - SC Support - Posts: 38150
Refer to the following information for how the coloring is determined. It is fully explained if you go through it step-by-step:
Volume By Price Study: Bid Volume and Ask Volume Coloring Method
