Date/Time: Tue, 25 Feb 2025 01:40:22 +0000
AMP
View Count: 1102
[2021-03-31 15:23:46]
User557529 - Posts: 4
As of April 1st, AMP will no longer giving tech support or any other support for Sierra/Danali accounts.
Is there another Broker that that works well with your system?
Please advise.
[2021-03-31 19:12:44]
John - SC Support - Posts: 38150
We would recommend looking at any of the brokers that support the Sierra Chart Order Routing Service. You will find a partial list at Step #2 here:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
Otherwise, any broker that supports the Trading Services that we support. You will find that list here:
Supported Data and Trading Services: Supported Services
[2021-04-01 02:53:34]
From our perspective it does not matter what broker you use, but we are curious why this matters:
Is it their position, that they will not even set up a trading account to use with Sierra Chart? That cannot be true because it is one of the supported platforms on their website.
But we would rather you do use the Sierra Chart Order Routing Service because it is a very good service.
Date Time Of Last Edit: 2021-04-01 02:53:56
[2021-04-01 03:26:03]
User160234 - Posts: 3
Hi, I am a new user of AMP. I was just on the chat support with AMP today and they gave me assistance on how to set up AMP with Sierra Chart. However, today is not 4/1 yet, so maybe that is why they still provided support. However, I think it doesn't matter. I have been browsing the Sierra Chart support board and using the support token service, and both are very helpful. I don't think the broker matters at all. Right now, I am only getting the CQG order routing from AMP and paying trade commissions to them. The Denali feed and everything else is through Sierra Chart. I can't wait for the CME direct order routing to be rolled out, then I won't have to use CQG order routing from AMP either.
