Date/Time: Tue, 25 Feb 2025 01:15:44 +0000
Initial Balance Study Not Plotting Correctly on 15 Min Chart
View Count: 679
[2021-03-31 15:02:00]
cmet - Posts: 649
Have the Initial Balance study set to start/end times for the first hour in ES_F.
On a 1 minute chart, the study plots correctly at the end of the first hour of RTH.
However, on a 15 minute chart, it keeps adjusting after the IB is closed. It then plots at the high or low of that bar. Exact same settings.
For example today (3/31/21): IBH - 3969.25, IBL - 3956.50.
On the 15 minute chart: IBH - 3973.25 (plotted at top of bar which begins at 7:30 pacific - after close of IB), IBL is correct since the low was the low of the firt 15 minute bar.
[2021-03-31 18:44:05]
John - SC Support - Posts: 38150
What are the following Inputs set to:
- TPO Letter/Block Time Period Length
- TPO Letter/Block Time Period Length Unit
- Initial Balance Range
[2021-03-31 21:58:58]
cmet - Posts: 649
This is simply the Studies > Initial Balance study, not TPO.
However, just updated to 2245 and I see it plots correctly on the 15 minute now.
Not sure if there's something different there or if it was some sort of refresh/update issue in real time today.
Date Time Of Last Edit: 2021-03-31 21:59:09
