Date/Time: Tue, 25 Feb 2025 04:45:35 +0000
Chart Values/Cross hair
View Count: 1596
[2021-03-31 14:57:48]
User106509 - Posts: 6
on my chart the chart values/crosshair is white in color.
How do i change that color of the chart values/crosshair?
Thank you
Stephen
[2021-03-31 15:35:31]
User75002 - Posts: 117
Click on Global Settings | Graphics Settings - Global
About 1/4 the way down the list is Chart Values: Crosshair
Date Time Of Last Edit: 2021-03-31 15:36:03
[2021-03-31 15:44:38]
Thank you.
I did that. The color did not change
[2021-03-31 15:49:55]
Check to make sure your chart is set to use the global settings.
Click on Chart | Graphics Settings - Chart
If the box "Use Global Graphic Settings Instead of These Settings" is unchecked, then you will need to change the color using this box which only applies to that chart.
Date Time Of Last Edit: 2021-03-31 15:50:58
[2021-04-01 13:09:34]
On the attached files, i have circled in black color. How do i change that color of the crosshair. It is not at all visible.
Thank you.
Private File
Private File
[2021-04-01 13:24:06]
I cannot see the attached files. They are marked private. Hopefully SC can see them and help as well.
[2021-04-01 13:29:20]
Thank you.
imageCapture.PNG / V - Attached On 2021-04-01 13:28:59 UTC - Size: 4.14 KB - 267 views
imageCapture1.PNG / V - Attached On 2021-04-01 13:29:07 UTC - Size: 3.85 KB - 247 views
[2021-04-01 13:41:52]
If you want the text boxes to be a different color, try using the graphic setting - Chart Values: Color of the Price and Time Boxes. This will change the color of the boxes in the axis. This allows you to have crosshair white and text box a different color. I made mine blue and my crosshair black. Hopefully this is what you are looking for.
Date Time Of Last Edit: 2021-04-01 13:45:01
image2021-04-01_09-43.png / V - Attached On 2021-04-01 13:44:16 UTC - Size: 2.1 KB - 246 views
