Date/Time: Tue, 25 Feb 2025 01:23:58 +0000
CQG Denali change
View Count: 682
[2021-03-31 12:09:16]
User752442 - Posts: 36
I would like to switch from the CQG / AMP datafeed to the Denali datafeed on April 1st. How do I best do this to not stand without data feed tomorrow.
cancel today 03/31 CQG and tomorrow of April 1st. activate the Denalifeed?
need the free month
Date Time Of Last Edit: 2021-03-31 12:14:16
[2021-03-31 14:00:24]
John - SC Support - Posts: 38150
What you stated is what you need to do. Let your broker know that you want the CQG data to end on March 31, but you still want the data through today.
Then do the first 2 sections of the Setup Instructions for the Denali Exchange Data Feed today as well, this will take you through Signing the Agreements, which will allow you to get everything done in just a few minutes on the morning of the 1st. The instructions start here:
Again, just do the first 2 sections today (through Sign the Agreements) and then the rest tomorrow.
[2021-03-31 18:29:29]
I'am from Germany and I need the Eurex Data
is there no problem when i activate the denali/eurex data directly 1 April in the morning
in my local timezone?
Date Time Of Last Edit: 2021-03-31 18:45:16
[2021-03-31 20:19:00]
There will not be any problem activating the exchanges (both for the CME Group and EUREX) on April 1 in your time zone.
If you can, you should fill out the Exchange Agreements for both the CME Group and EUREX as soon as possible, at the following links:
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements_EUREX
You will need to fill both sets out separately, as the Vendor of Record for each exchange group is different.
