Date/Time: Tue, 25 Feb 2025 01:58:12 +0000
Choosing Percent Color Threshold in Market Depth Historical via buttons
View Count: 472
[2021-03-31 08:11:23] |
User275592 - Posts: 97 |
Hi, i am using your GREAT Market Depth Historical Study. I'd like to be able to choose rapidly between different sets of Percent Color Threshold. Is it possible to set buttons in a control bar to do this ? if not, is it possible to do this via ACSIL ? via another tool ? Thank you very much in advance for your help |
[2021-03-31 15:39:57] |
John - SC Support - Posts: 38150 |
You can do it using ACSIL. Refer to the following: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events: Advanced Custom Study Buttons and Pointer Events For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
