Date/Time: Tue, 25 Feb 2025 01:06:57 +0000
Need Help: Study not loading at times on startup
View Count: 468
[2021-03-30 22:08:11]
rahul - Posts: 167
Hello Sierra Chart engineers,
I have a couple studies that don't load at times when Sierra Chart is started and the chart loads on startup. To get the charts to load properly I have to either:
1. Open the Chart Studies dialog box and click Apply to reload the studies.
OR
2. Or click on Edit -> Reload All Charts
Is there any way in my ASCIL code to check if the study has been loaded? Can you provide a code example to fix this or a workaround?
FYI: this behavior has been happening for a long time (many previous versions up to v2238), but I ignored it as I was manually present in front of PC. But now, I am not present so I need the studies to load properly when SC starts up.
Date Time Of Last Edit: 2021-03-30 22:09:39
[2021-04-01 03:42:15]
You need to determine what the problem is in your custom study. This is not a Sierra Chart issue.
You can see that all Sierra Chart provided studies work properly and have no such issue like this.
