Date/Time: Fri, 18 Sep 2026 13:06:03 +0000
Option for US equities real time data with DOM
View Count: 1007
| [2021-03-30 19:59:54] |
| User563998 - Posts: 17 |
Can you please suggest me option for getting real time data including DOM for U.S. Equities e.g TSLA, AMZN, AAPL ? My understanding is Denali cant support it. But can Sierra chart exchange data feed support DOM ? Date Time Of Last Edit: 2021-03-30 20:04:14
| [2021-03-30 20:14:31] |
| John - SC Support - Posts: 47930 |
You would just need to add the Sierra Chart Exchange Data Feed to your services and within the Sierra Chart Exchange Data Feed enable the U.S. Equities exchange. There is no problem having both the Denali Exchange Data Feed and the Sierra Chart Exchange Data Feed at the same time. You will find the information for the Sierra Chart Exchange Data Feed including Setup Instructions here: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-03-30 20:20:44] |
yes but the link you gave says, DOM is not supported for U.S. Equities (NYSE, NASDAQ, AMEX) Is that true or it does support DOM ? |
| [2021-03-30 21:09:42] |
Sorry, different terminologies. We do not have Level 2 Market Depth Data, if that is what you mean by DOM. Right now, if you want the Level 2 Market Depth Data you would need to use Interactive Brokers data. We are working on a new NASDAQ data feed that will include the Level 2 data. We hope to have it available in a few months. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-30 21:10:55
| [2021-03-31 16:17:20] |
ohk. I will use IB data. I am paid for package 11 for next 2.5 month. Will I able to change my package from package11 to package 5 now ? |
| [2021-03-31 19:33:15] |
You can continue to get your CME data from us and get your Stock data from IB. You do not need to stop using the Denali Exchange Data Feed if you do not want to. But, if you do want to do this, then you can change your Service Package at any time. Just be aware that as soon as you change your package, you will no longer be able to receive the CME Data, regardless of how much time is left in the month for the exchange itself. To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
