Date/Time: Tue, 25 Feb 2025 01:16:26 +0000
Study for High and Low of a Candlestick?
View Count: 532
[2021-03-30 19:57:39]
User344276 - Posts: 68
Is there a study that will draw horizonal lines for the high and low of a 15 minute candlestick each time it is formed on the chart?
[2021-03-30 20:12:28]
John - SC Support - Posts: 38150
We are assuming that it is a 15 minute chart, so you are wanting the lines on every bar. To do this you would use two of the Study Subgraph Reference and set one to reference the Main Chart Graph High and the other the Main Chart Graph Low. Then set the Draw Style for the subgraphs to Dash.
Refer to the following:
And refer to the following for changing the Draw Style:
Chart Studies: Subgraphs Tab >> Draw Style
