Date/Time: Fri, 18 Jul 2025 22:48:43 +0000
Interactive Brokers - bracket orders cancelled subsequently
View Count: 1017
[2021-03-30 18:28:51]
tomas262 - Posts: 152
seems IB cancels my bracket order for a short position opened by my ACSIL code for some 'unknown' reason. Can it be decoded somehow from the log? With AMP all worked perfect but now with IB the same system have the brackets cancelled now 2 days in a row. Brackets are set to be GTC :-/
Seems it has been cancelled at 2021-03-30 00:00 for the short opened at 2021-03-29 14:33
TradeActivityLog.txt attached
TradeServiceLog:
Interactive Brokers | Requesting Open orders. | 2021-03-29 14:54:58.816
Interactive Brokers | Received Open orders end message. | 2021-03-29 14:54:58.830
Interactive Brokers | Received Open orders end message. | 2021-03-29 16:46:11.074
Interactive Brokers | Requesting Open orders. | 2021-03-29 16:46:16.077
TradeActivity files query time: 0.040596 seconds. Entries: 0. Current queries: 1 | 2021-03-29 16:46:16.119
Interactive Brokers | Requesting historical order fills for account U732*. Starting date: 20210328-00:00:00 | 2021-03-29 16:46:16.119
Interactive Brokers | Received Open orders end message. | 2021-03-29 16:46:16.199
Interactive Brokers | Received 8 historical order fills from TWS. | 2021-03-29 16:46:16.280
RemoveDuplicateFills | TradeAccount: . DatesOfRecordsToInsert: 2021-03-29, . MostRecentFileNameSearched: TradeActivityLog_2021-03-29_UTC.U7325213.data. RecordsRemovedCount: 8. OriginalRecordsToInsertCount: 8. RecordsToInsertCount: 0 | 2021-03-29 16:46:16.342
TradeActivity files query time: 0.036481 seconds. Entries: 0. Current queries: 1 | 2021-03-29 16:46:16.343
Interactive Brokers | Requesting Open orders. | 2021-03-29 16:46:27.039
Interactive Brokers | Received Open orders end message. | 2021-03-29 16:46:27.049
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 63. InternalOrderID: 17993. | 2021-03-30 00:00:01.693
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 62. InternalOrderID: 17992. | 2021-03-30 00:00:01.693
Trading message from IB: Order rejected - reason:No such order: order done. Error Code: 201. ServiceOrderID: 63. InternalOrderID: 17993. | 2021-03-30 00:00:01.717 *
Interactive Brokers | Requesting Open orders. | 2021-03-30 00:00:15.994
Interactive Brokers | Received Open orders end message. | 2021-03-30 00:00:15.997
Trading message from IB: Order Event Warning:Attribute 'Outside Regular Trading Hours' is ignored based on the order type and destination. PlaceOrder is now being processed. Error Code: 2109. ServiceOrderID: 65. InternalOrderID: 17994. | 2021-03-30 02:32:17.433
Interactive Brokers | Requesting Open orders. | 2021-03-30 02:32:31.638
Interactive Brokers | Received Open orders end message. | 2021-03-30 02:32:31.641
Interactive Brokers | Requesting Open orders. | 2021-03-30 03:19:01.040
TradeActivity files query time: 0.012252 seconds. Entries: 0. Current queries: 1 | 2021-03-30 03:19:01.098
Interactive Brokers | Requesting historical order fills for account U732*. Starting date: 20210329-00:00:00 | 2021-03-30 03:19:01.098
Interactive Brokers | Received Open orders end message. | 2021-03-30 03:19:01.329
Interactive Brokers | Received 1 historical order fills from TWS. | 2021-03-30 03:19:01.346
RemoveDuplicateFills | TradeAccount: . DatesOfRecordsToInsert: 2021-03-30, . MostRecentFileNameSearched: TradeActivityLog_2021-03-30_UTC.U7325213.data. RecordsRemovedCount: 1. OriginalRecordsToInsertCount: 1. RecordsToInsertCount: 0 | 2021-03-30 03:19:01.396
TradeActivity files query time: 0.027951 seconds. Entries: 0. Current queries: 1 | 2021-03-30 03:19:01.396
Interactive Brokers | Requesting Open orders. | 2021-03-30 03:19:15.260
Interactive Brokers | Received Open orders end message. | 2021-03-30 03:19:15.323
Trading message from IB: Order Event Warning:Attribute 'Outside Regular Trading Hours' is ignored based on the order type and destination. PlaceOrder is now being processed. Error Code: 2109. ServiceOrderID: 68. InternalOrderID: 17996. | 2021-03-30 03:25:18.624
Trading message from IB: Order Event Warning:Attribute 'Outside Regular Trading Hours' is ignored based on the order type and destination. PlaceOrder is now being processed. Error Code: 2109. ServiceOrderID: 67. InternalOrderID: 17995. | 2021-03-30 03:25:18.643
Interactive Brokers | Requesting Open orders. | 2021-03-30 03:25:32.939
attachmentTradeActivityLog.txt - Attached On 2021-03-30 18:25:47 UTC - Size: 70.76 KB - 352 views
[2021-03-30 19:25:03]
Make sure you use a Time in Force of Good till Canceled for those Attached Orders:
Attached Orders: Time In Force
Update: Actually we see that you have said this is already the case. So we do not know the reason. You need to ask Interactive Brokers.
Date Time Of Last Edit: 2021-03-30 19:26:02
[2021-03-30 20:48:13]
IB said: "It shows the order was canceled by you the user of the acct on 03/30 at 01:00:01.217" which is very strange since I was sleeping at that time :)
Will keep my eye on the currently open position whether the issue happens again so I can get some new data
[2021-03-31 07:19:55]
hm it happened again today, 3 times in 3 days
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 78. InternalOrderID: 18006. | 2021-03-31 00:00:01.295
Trading message from IB: Order rejected - reason:No such order: order done. Error Code: 201. ServiceOrderID: 78. InternalOrderID: 18006. | 2021-03-31 00:00:01.296 *
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 77. InternalOrderID: 18005. | 2021-03-31 00:00:01.607
attaching some more data into next post ....
imageSC-IB-setting.png / V - Attached On 2021-03-31 07:18:45 UTC - Size: 129.49 KB - 223 views
imageTWS 2021-03-30 16_15.png / V - Attached On 2021-03-31 07:18:55 UTC - Size: 139.57 KB - 208 views
attachmentTradeActivityLog.txt - Attached On 2021-03-31 07:19:10 UTC - Size: 8.9 KB - 306 views
[2021-03-31 07:20:57]
IB chat snapshot + Audit Trail from TWS
Private File
attachmentIB-chat.txt - Attached On 2021-03-31 07:20:36 UTC - Size: 1.64 KB - 341 views
[2021-03-31 13:39:40]
This is the reason for the canceled orders:
Orders  2021-03-31 00:00:00.665  M2K-202106-GLOBEX-USD  M2K-202106-GLOBEX-USD [C] 60 Min #1 | Cancel Orders at set time for Symbol and Account  18006  78  Stop  1  Sell  2184.4    Pending Cancel      **  Close  18004  1          0.00
Orders  2021-03-31 00:00:01.295  M2K-202106-GLOBEX-USD  IB order status update  18006  78  Stop  1  Sell  2184.4    Canceled      **  Close  18004  1          0.00
So you have enabled that functionality on the Trade Window:
Basic Trading and the Trade Window: A >> Flatten And Cancel at Set Time
Date Time Of Last Edit: 2021-03-31 13:40:02
